Styrofoam Cello
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=46100
Author:  Pat Hawley [ Mon Jul 27, 2015 4:39 pm ]
Post subject:  Styrofoam Cello
Styrofoam, who've thought!
http://deredactie.be/cm/vrtnieuws.english/News/1.2362321?playlist=7.39638
Author:  Chris Pile [ Mon Jul 27, 2015 6:35 pm ]
Post subject:  Re: Styrofoam Cello
I think I need some more details...
Author:  DanSavage [ Mon Jul 27, 2015 6:40 pm ]
Styrofoam (EPS) is a natural amplifier. To see this for yourself, take a piece of music wire and tap it on a table top.
Then, push the wire into a block of Styrofoam and tap the wire again on the table top. It will be much louder.
Technically, styrofoam is the open cell green foam used by florists. The white foam he used is expanded bead polystyrene foam (EPS) which is the same stuff used for disposable coffee cups and ice coolers.
Author:  DanSavage [ Mon Jul 27, 2015 6:42 pm ]
http://makezine.com/2015/07/22/unique-d ... his-cello/
http://www.classicfm.com/instruments/ce ... mEHMzuE.97
Author:  PB+J [ Mon Jul 27, 2015 8:38 pm ]
It must be braced in someway? It looks like it has a narrow wood top with foam "wings. I love this kind of thing. Wish they had given a longer sound clip.
Thinking about it, the stiffness to weight ratio of that white foam is pretty incredible
Author:  Mike OMelia [ Mon Jul 27, 2015 10:12 pm ]
That's crazy. Bet u couldn't build a steel string that way.
Author:  Henk H [ Wed Jul 29, 2015 7:26 am ]
This styrofoam cello was developed by Tim Duerinck, a musical instrument manufacturing student at the College of Ghent (Belgium). For those who read Dutch, his complete master thesis describing the development of the instrument can be found at : http://www.scriptiebank.be/sites/defaul ... nten_0.pdf
Dimensions :
Length 760 mm
Upper bout 372 mm
Waist 222 mm
Lower bout 460 mm
Depth 116 / 119 mm
Materials / construction :
Back, sides and neck : sycamore maple
Bridge : European larch
Top : 15 mm styrofoam 15 kg/m^3 reinforced by a 120 mm wide, 1 mm thick veneer strake (European larch) on both sides running over the full length of the instrument body. An extra reinforcement by a 1 mm carbon plate of 120 x 90 mm was glued onto the veneer both on the in- and outside i.w.o. the bridge.
The height of the 11 / 12 mm bass bar, nor the dimensions of the soundpost are given. Their position is described as “standard” (bass bar under bass side bridge foot, soundpost under treble side bridge foot)
The strings make an angle of 154 degr. over the bridge, thus exerting a load to the top of the cello which is said to vary depending on the brand and type of strings, from 417 to 507 N. Roughly twice as high as from a floating bridge on a guitar top. Since the styrofoam cello apparently sounds much louder than a traditional one, it seems worthwile to experiment with styrofoam guitar tops as well !
Author:  jfmckenna [ Wed Jul 29, 2015 10:10 am ]
Wow, yeah, who woulda thunk?
Author:  Markus Schmid [ Wed Jul 29, 2015 10:21 am ]
How much do you bet?
